SecuritySpy is using more and more RAM
MacMini M2 pro, 16 GB RAM, macOS 26.3.1, 5 cameras, 4 of which provide night-time surveillance using AI.
SecuritySpy's main memory usage is increasing day by day:
App restarted
Day 1: Activity Monitor: 558 MB SPs dashbord shows: 113 MB
Day 2: Activity Monitor: 4,2 GB SPs dashbord shows: 1,5 GB
Day 3: Activity Monitor: 7,8 GB SPs dashbord shows: 430 MB
Day 4: Activity Monitor: 11,6 GB SPs dashbord shows: 830 MB
The data was always recorded at 8 o’clock in the morning. At that time, no detection was active. Does anyone else have a similar problem?
Thanks.
  • Interesting. I just had a look (running SS 6.19b7) and it's using 6.10GB on my Intel Mac (Sequoia 15.7.4).
  • This is a known bug in earlier 6.19 beta versions - please update to the latest beta (currently 6.19b10) as this should fix it. There is also a (far less severe) memory leak issue in the current 6.18 release that is fixed in this latest beta. This will be released as an official 6.19 update this week, so feel free to wait for this if you prefer.
  • Installed version is 6.18, no beta. I'm waiting for the version 6.19.
  • Thanks, Ben. I did update to the latest beta.
  • Version 6.19 has just been released and is available from the SecuritySpy download page.
  • Hi, the issue was resolved with the update to version 6.19.
    Thanks.
  • Great to hear that, thanks for reporting back.
  • Skerik
    edited November 12
    Hi, sorry to bump an old thread - I'm looking at converting from Blue Iris on an old Win box that has become unstable, to SS on an M6 Mac Mini. I'm currently running a 16GB M1 Mini as a digital front end for my stereo (using Roon, Tidal and other stuff) and on a typical evening it's showing about 12-13GB in use. To run a mix of 3 x 2K & 2 x 4K cams with SS, how much RAM would be typical?
    Would bumping up to 24GB on an M6 be more then sufficient, or should I think about biting the bullet and doing a CTO for 32GB? (There's a decent current deal on the 24GB / 512TB config, not sure if any Black Friday deals will be available for 32GB but seems less likely given it's a custom config. That's a $350 price delta, ugh.) From what I've seen so far, I think the 24GB config should be sufficient when there aren't memory leak bugs to be squashed. 😝
    [Edit: I found the requirements calculator, and it looks like the 8GB bump from 16GB to 24GB should be fine, theoretically.]
  • Hi @Skerik since you already have the M1 mini, try that first. Running your small selection of cameras in SecuritySpy shouldn't add too much memory usage, and you may find that the machine performs perfectly well with its 16 GB. Enable the option in SecuritySpy under Settings > Email to send you error reports, and set this to also include warnings. Then, SecuritySpy will email you if it detects elevated memory pressure. Only if this happens frequently, you could then look at upgrading to a 24 GB Mac.
    The exception to this is if you are planning to use SecuritySpy's "Smart Search" feature (described in the manual under Settings > General) - this uses AI models that increase the RAM requirement significantly, and for this plus the other processes running on the machine, you'll likely need 24 GB.
