Reolink problem
I've got 3 working Reolink cameras and I've just added a 4th. They are all RLC-510A. However I cannot see the 4th in Security Spy but all the settings look identical. I can see it both in the Reolink IOS app and the Mac app. Any ideas please.
  • Ben, I've just remembered you gave me a fix for this previously when I added a Reolink. I seem to remember that Reolink had changed the default settings, something to do with RTSP
  • Now fixed it thanks by enabling RTSP on the camera
  • Great to hear you found the fix. Yes, for some inexplicable reason, Reolink cameras ship with the RTSP/ONVIF options disabled, so these must be manually enabled in order to use the camera with an NVR such as SecuritySpy.
  • I have resurrected this thread because I have a further problem with Reolink cameras. At one particular installation I have 4 Reolink cameras. 2 days ago 2 of these cameras stopped working in Security Spy. I get the error "Connection closed". However I can see them quite happily in the Reolink app on my phone or if I go to their web address on the Mac. The 2 cameras in question are older versions than the other 2 which seem to be V2 of the same unit. (RLC-510A). I have checked that RTSP & Onvif are still enabled.
    It's really curious because both units went off line at the same time in the middle of the night Saturday. Any thoughts, other than replacing the 2 older units ?
  • Update to the above. I brought one of the cameras to my home network and it worked there with Security Spy. When I returned it to its original location it started working again. Turned out all I needed to do was power cycle it and when I did the same with the other it also worked. It was quite difficult to get access to where it was powered from which is why I didn't try that at first. Still very curious though because it was working via the Reolink app but just not Security Spy.
  • I'm a glutton for punishment and I have NINE Reolink cameras, including a doorbell. I love them.
    One is attached via a Mesh node to the garage and every so often needs a power cycle. 🤷‍♂️ It's plugged into a smart plug so I can power recycle it from my iPhone from wherever I am.
