new SV3c camera and 2-way audio
Hello!
I just picked up a new SD5POE-5MP-HX camera. I could only get it working using one of the auto profiles, but none of them support 2-way audio. Digging into the camera it looks like it is using G711, which from previous posts is supported as that is what Amcrest uses?
Is there a way to modify profiles to combine all of the working bits together?
Thanks so much!
  • Sorry but at this time, two-way audio is supported only for Axis, Amcrest, Dahua and Hikvision cameras. We have been working on a universal ONVIF implementation of this, but have hit some problems that mean this isn't working well enough for general release. I hope that we will be able to get the ONVIF implementation working at some point in the near future, at which point it is likely that two-way audio will work in any ONVIF compliant camera that supports two-way audio.
  • Thanks for the update Ben! Looking forward to it.
