Reolink RLC-823A working with latest firmware
Hi all,
I just wanted to drop a line and say that I just got a Reolink RLC-823A in. It's working great with SecuritySpy using the latest firmware (v3.1.0.956_22041511_v1.0.0.30). After upgrading it, I had to go turn ONVIF on in the camera settings. After that, everything works.
I know Reolink isn't a favorite here, but this camera is pretty full featured for its price, so it's hard to pass up.
Better off with any Amcrest IMHO
but good on you for getting it working!
This is very useful to know - many thanks @boisy. It seems that newer Reolink cameras work much better than than older models, many of which had big problems producing valid RTSP streams.
I've been playing with this camera for a few days and have it set up remotely at a construction site that I'm monitoring.
It continues to perform pretty well with SecuritySpy. The only issue that I seem to have is that I am unable to hear audio (the camera is a two-way system with both a speaker and a microphone). The speaker icon doesn't appear at the top right window of the video for the camera. Ben, is this something that would be possible to support?
Camera-to-computer audio should certainly work, but not computer-to-camera audio (this is currently supported for Axis, Dahua, Hikvision and Amcrest cameras only).
Do you have audio set to "This network device" in SecuritySpy under Preferences > Cameras > Audio?
Are there any audio settings available on the camera? Is this turned on? What audio encoding settings are available (e.g. G.711, PCM, AAC etc.)?
Hi Ben,
The Audio device pop-up is set to "This network device" for this camera.
I looked in the camera settings and sure enough, the audio recording was turned off. Flipping that switch did it, and now I can hear audio :)
Thanks for the suggestion!
Great to hear that, I'm sure this information will be useful for other users too.
Thanks Ben. I also sent you a PM regarding this. Please check.
Just a 'me too' post:
I bought a RLC-822A in the fall of 2021and it was terrible at first. Once I got a newer firmware, it worked great with SecuritySpy. The camera view is a second or two behind the others, but I think that's just due to the higher bandwidth or maybe the H265 processing time.
That said, I might try out a Hikvision next instead of getting another Reolink. The ColorVu feature looks impressive.
Hi @Gus great to hear that, thanks for the useful feedback.
