Doorbird
Hoping some one can help me. I have just got a Doorbird, intercom and am wanting to record the video camera that is attached. I have had a little look at the api and have inserted the line http:///bha-api/video.cgi (with the IP address) as listed, but I don't seem to be getting a video feed. If I put it into a browser I get the video showing up. Could some one have a little look and tell me what I am missing? Its a very short API available at https://www.doorbird.com/downloads/api_lan.pdf?rev=0.9
Thank you
Thank you
Here is how you would set this up in SecuritySpy:
- In the Cameras section of the Preferences window, create a new network device.
- Under the Device tab, set the device type to "Manual configuration”.
- Enter the camera's IP address but leave the Port fields empty.
- Enter the camera’s username and password
- Select HTTP from the Format menu.
- Enter video.cgi as the Request
Does this work? -
Hi, thanks for the answer. I just gave that a try and no joy still. I also ticked the SSL and tried that just encase and that still didn't sort it.
Wouldn't the request be more of the URL scheme like...
bha-api/video.cgi -
Yes! Thank you so much thats spot on the picture is showing!
Audio parameters above do not work for me. Video ones, as corrected, do.
