SS4 cuts DV camera connection... repeatable
Gregory
edited July 2016 in SecuritySpy
with the latest version of SS (32-bit), there is a problem where SS cuts the connection to my Sony mini-DV camera after a short period of up-time. this happens *every* time. this did *not* happen with the v3. I have to relaunch SS to get the connection back but it only lasts minutes before SS cuts the connection again.
error displayed:
Error from camera "DCR-PC120E", it will be closed.
(Failed to obtain DV video frame 47530,12 Couldn't allocate memory)
bug in SS4?
Gregory
OS X 10.11.5 (15F34)
Mac Pro (Early 2008)
16 GB 800 MHz DDR2 FB-DIMM
ATI Radeon HD 4870 512 MB
    edited July 2016
    Hi Gregory, this certainly sounds like a bug, though it's not one we've seen as yet. We'll investigate and get back to you. When this happens, SecuritySpy should attempt to repeatedly re-connect to the device and it should come back online, are you seeing this?
    Is the error code always the same?
    It's related to audio capture - do you need audio for this device?
  • Gregory
    edited July 2016
    the error code is always the same.
    I'd prefer to keep audio capture...
    more relevant info ?:
    for security reasons, I have an account on my Mac set up specifically to run SS. most of the time, this account and SS are running 'in the background'; i.e., my own personal account is active in the foreground.
    if an error occurs while my account is active, SS doesn't re-establish the connection to the camera. if I switch back to the account running SS, there's an error 'beep' and SS re-establishes the connection to the camera; *possibly* only if the error log and/or the camera window is/are visible -- which was the case a few minutes ago -- I'll try to test these scenarios. I normally run SS with the camera (and log) windows closed to save cpu.
  • switched back to the SS account this morning after it stopped displaying the Sony camera. it didn't automatically reconnect, and the error in the log was different:
    "2016/07/20 09:08:49: No video from DV device "DCR-PC120E" - make sure a video source is connected to the device and that it is set to DV-out mode. 4.0.2,792,800 The operation timed out."
    relaunching SS connected immediately to the camera.
  • with 4.0.4, still losing the Mini-DV connection:
    2016/07/30 21:48:28: No video from DV device "DCR-PC120E" - make sure a video source is connected to the device and that it is set to DV-out mode. 4.0.4,792,800 The operation timed out.
    2016/07/30 21:48:49: No video from DV device "DCR-PC120E" - make sure a video source is connected to the device and that it is set to DV-out mode. 4.0.4,792,800 The operation timed out.
    2016/07/30 21:49:10: No video from DV device "DCR-PC120E" - make sure a video source is connected to the device and that it is set to DV-out mode. 4.0.4,792,800 The operation timed out.
    2016/07/30 21:49:31: No video from DV device "DCR-PC120E" - make sure a video source is connected to the device and that it is set to DV-out mode. 4.0.4,792,800 The operation timed out.
  • 4.0.5 seems to have solved the problem. thank you.
