Sensitivity
Hi all - perhaps this is a daft question, however I would like to see if I can undersand these settings correctly.
With regard to the sensitivity of Motion Detection, how does the % work. Does a higher % value mean a greater sensitivity or vice versa?
Same goes with the audio detection trigger...higher % means greater sensitivity?
Many thanks
Philip
Many thanks
Philip
For audio, this is a bit different because audio detection is triggered when the audio level exceeds a certain set threshold, expressed as a percentage. So if you have an audio detection trigger level of 20% you will capture many more events than a trigger level of 80%.
I can see that this might be a bit confusing because higher numbers mean different things for video and for audio. This is simply a result of the very different methods of detection that need to be employed for video vs. audio. We may change the naming of the settings in the future to make them more consistent with each other, but for now this is the way things are.
