SecuritySpy accept incoming network connections?
Hi Ben-
At each startup I'm getting the intercept box that wants to allow incoming connections: " deny", " allow".
My setting in the Security preference panel is clearly "allow incoming connections" for SecuritySpy.
Is there some Pref or something I have to kill and rebuild to get this functionality back on startup of securityspy ? I did remove it and then re-added to the preference pane… But that didn't help.
TIA
Jay
TIA
Jay
Hi Jay, this is not something I've come across before. Searching internet forums reveals other people experiencing some strangeness with these firewall warnings. What system version are you using, and what SecuritySpy version? One thing to try seems to be to remove ALL rules from the firewall and then adding them back again.
