FTP vs. Capture destination
FTP is for off-site backup for captured footage, in case the recording computer/drive is damaged or stolen by an intruder.
In your case it sounds like you should simply be mounting the disk on your Mac and setting it as a capture destination in SecuritySpy. SecuritySpy will then record everything directly to the NAS.
Hope this helps! -
It makes perfect sense. Thanks for the quick reply!
