Cameras not capturing video
I recently upgraded my server to a MacMini, 2.3ghz Core Duo, 8gb RAM, OSX 10.9.3 and I have difficulty recording video.
I have 3 HIKvision cameras(DS-2CD2032) set at Res=1028x720, FrameRate=10, Iframe=20, Video Quality=Medium, Encoding=H.264. With these settings the activity monitor shows the CPU at 31%.
SecuritySpy is set to "no recompression"
I not able to get the video to record to the default folder. I did notice in the activity monitor, the network was very busy at 1.85 MB/sec almost all due to SecuritySpy. Changing the video settings in SS to JPEG HTTP reduced Data Received to 390 KB/sec (yes KB)! It seemed to correspond with recording starting to work. I thought that it would be best to use the H.264 setting, but perhaps I am wrong. Is it possible that stopping and restarting SS somehow corrected the recording issue and was related to the network activity?
Thanks for any advice
The JPEG stream from this particular camera is at a much lower frame rate than the H.264 stream - this explains the difference in data rate transmitted from the camera to the computer. I would recommend you use the H.264 stream.
To get SecuritySpy to record, make sure you have enabled a capture option in the Camera Settings window (either continuous capture or motion detection), and then set the camera to Active mode (via the Control menu, or by right-clicking on the camera in any window). The camera must be in Active mode for any recording to take place.
