play audio in main viewer?
Hi, i like that recent versions of SS have added the ability to record audio from the Ubiquiti dome camera. i'm using that cam and recording it's audio successfully.
I have a monitor attached to my Security Spy server and would like to monitor the audio in real time - not just for prerecorded events. Is this possible? the viewer doesn't seem to play audio and i see no option to do so.
perhaps i'd like to monitor audio only under certain circumstances - like when there's motion detected... but i'd first just like to know if it's possible, or if i'm missing something.
thanks.
thanks.
Hi - if you open the Camera Status window in SecuritySpy you should see a small speaker icon next to any camera that has audio. If you click this speaker icon, SecuritySpy will play the live audio from the camera through the computer's speakers (or other audio output as set in the system preferences).
