Storage Location
I moved securityspy to a different user on the computer and the storage location has a correct location and a blank one with an X through the folder. How do I get that blank folder with the X through it deleted?
There are two icons to the right of the storage location box: the folder icon, which you can use to set a location, and the folder-with-cross icon, which you can use to clear the currently-set location. If there were a problem with the currently-set location, you would see a yellow warning triangle that explains the problem, so as long as you don't see this, there is no problem with your settings.
