control PTZ with arrow keys
It looks like the latest update 6.1.7 disabled the ability to control the PTZ cameras with the arrow keys, either while having that camera open in its own window or after clicking on the camera in the "all cameras" window. Is there a way to get this back, I looked in every place I could in the settings area.
Try holding the Shift key, or applying Caps Lock - the arrow keys should then work for PTZ control. Does that do it?
Arrow keys without modifiers are now used to control the full-screen display (enter/exit single-camera mode, switch between cameras), so we needed a way to distinguish between these commands vs. PTZ commands.
yep, that fixed it. Thanks.
