Control4 X4 - Interface / SS Widget ?
X4 is officially out and seems a huge improvement. C4 have almost caught up to maybe …2011. A big leap from where they were which was about 1994. :-) It's like the leap from DOS to MacOS.
The new UI allows for significant customization (at least compared to former C4 UI). Among other things is support for displaying streams (surveillance, programming, etc.) in a UI panel - either continuous or based on a trigger.
Has anyone looked at how this will work with SS? Will it require a SS specific widget?
I can think of a long list of desirable features in a SS widget :-)
I'm not really sure about this, because we don't ourselves test Control4 or make widgets/drivers available for it. One thing you can try is the existing SecuritySpy Control4 driver, to see if it still works with the new X4 operating system. It's possible that it will, but likewise it's possible that there will be compatibility issues, so your testing feedback would be helpful here.
Still waiting to upgrade our system. Probably in the next couple of weeks.
I wonder if Chowmain might have something that would work or be easy to modify.
