One Movie per day setting in Motion Capture..
At first I thought the setting had been dropped, but then noticed it now in the "Advanced" settings. Also seem to be "not recommended". I've been using the "one movie per day" since I started using S.S., whats changed?
  • AI-based search via the web interface and iOS app (e.g. finding all recordings that contain a human) is file-based and requires that there is one movie per event in order to work properly. If you don't use these features, you can continue to use the one movie per day recording option without any other negative consequence.
