Using web server scheduling in Home assistant
Hi, I want to update the schedules of multiple cameras with one url. However I can only get this to work with the first camera. How do I add multiple cameras. I know I can apply the same schedule to mall cameras using '-1' but I want different settings for internal and external cameras
http://test.viewcam.me:8000/setSchedule?cameraNum=3&schedule=1&mode=MA&cameraNum=4&schedule=0&mode=MA&cameraNum=1&schedule=0&mode=MA&auth=Hash hash hash
Can anyone advise?
There are two ways to do what you want. The first way is to use the setSchedule request with a cameraNum that equals 1000+n where n is a group number (groups of cameras can be defined under Preferences > Groups). This is an undocumented feature that our iOS app uses.
The second way to do this (which is probably better), is to use schedule presets. You can define a schedule preset under Preferences > Scheduling, which sets schedules for any/all cameras you like. Then you invoke it with the request setPreset?id=123456
You can obtain group numbers and schedule preset IDs from the systemInfo XML document (see the SecuritySpy Web Server Specification page for info on this).
Hi Ben, thanks for the information - will experiment for the best option !
