Wyze Cam V3 - RTSP firmware hack
  • Hi,
    I recently got a WyzeCam V3 and found this firmware hack that enables RTSP.
    https://github.com/FiveLeavesLeft/WyzeCameraLiveStream
    I installed the hack and have been able to successfully open and connect to the stream using vlc with the following command: "vlc http://10.0.10.114:12345 --demux h264"
    What settings should I use to try and get this working in SecuritySpy? I've messed around bit, but haven't had any success yet.
    Thx.
  • It's unclear what format this stream is, because it starts with "http" and not "rtsp". In the readme of the firmware that you link to, I see no mention of RTSP. What makes you believe that this firmware enables RTSP support?
    Can you get any URL that starts with "rtsp://" to work with VLC?
  • Appears you're right. I kinda realized after I posted that it doesn't explicitly say it's RTSP.
    I can't get it to respond to an "RTSP://" based URL.
    I made the mistake because I saw someone refer to it as RTSP and seems like I got ahead of myself.
    thx Ben.
