I need to purchase four doorbell cameras to use with Security spy. I also have a significant Homekit environment but will prioritize compatibility with Security Spy over Homekit if needed. I have Cat6 run to each location and prefer hardwired. Good quality video over great night vision is a lower priority. I am currently considering DoorBird cameras as they also have internal speaker for sound. thanks in advance.
The DoorBird is fine, however SecuritySpy can't do two-way audio with this one. If you need two-way audio, then I would recommend going for a Hikvision or Dahua model.
Looks like the DS-KB6003-WIP and DS-KB6403-WIP don't have PoE but the DS-KB8113-IME1 does. The DS-KB6003-WIP requires 16-24 V AC while the DS-KB6403-WIP requires 12 V DC. This is quite surprising, I would expect them all to have PoE but apparently not.
Ben, Bones and abid, thanks for the thoughts.Im down to the wire to order something. POE is important as I ran cat 6. thoughts or guesses DS-KB8113-IME1 vs Ring Pro?
Wil there an option to for example the doorbell image to be seen as a PIP when the drivewaycam is fullscreen? Now i have to set the 2 images next to each other.
It is sad that the DS-KB8113-IME1 does not have POE. Let me know if any of you guys come across any decent doorbells that fulfil the following: 1. Work with SS 2. POE 3. 2-Way Audio 4. Good Nightvision.
