I'm afraid not - if you need audio in SecuritySpy, then the camera's microphone must be turned on permanently, with audio continuously streaming to SecuritySpy.
Is there a way to tie video motion detection together in some way? Something like... if motion detected and sound greater than threshold then do something end if
Hi @susscrofamorte I don't think this would work very well - I think you would miss a significant quantity of events that you would want to capture. SecuritySpy's motion detection and sound detection work independently, so that either one will trigger a recording.
