V380 wireless camera Noise on two way audio model.
Recently we bought a wireless camera from INTENDVISION DIRECT STORE on Aliexpress. the image and others are very good. however when test the two way audio function on phone . there are annoying noise on the phone APP. check the camera there are not any sounds on the camera itself.
Is that a software problem?
contact seller they said it's quiet normally when the phone and camera are close as there are circuit interference. can turn the volume down to make it better and far way from each other will help.
Not other method to solve this. however I think this may be one of the reason . there are any possible is about the software problem. as the camera itself without any noise but on the phone app there are noise.
Anyone have any solution for this problem?
