"Another copy of SecuritySpy is running"
McChiel
edited August 2018 in Installation
Hi all,
This happens every time after a power failure.
SS is for ever trying to initialise.
Finally I have to delete SS.
After re-installation it tells me "Another copy of SecuritySpy is running"
How is that possible if I had deleted the program? it must be in some register orso.
However I'd really have a solution for the initialising problem after a power failure
regards
Michiel
    edited August 2018
    Hi Michiel,
    It sounds like you have two copies of SecuritySpy on your Mac, and perhaps they are both set to automatically open upon login. I suggest you do a search for "SecuritySpy" and remove any duplicate copies of the software from your Mac - you should just have one single copy (the latest version) in your Applications folder.
    If it's taking a long time to initialise, this means it's probably looking for a custom capture destination that's missing. It will wait for a while for this to mount, and then it will eventually give up and use the default capture destination (~/SecuritySpy/Captured Files/). I suggest you go through each camera and set the capture destination again - either use the "Set Capture Destination" button to set a custom destination, or use the "Reset Capture Destination" button to clear any existing destination). This will clear any previously-remembered destinations that no longer exist. This setting is at Preferences -> Cameras -> Setup.
