Using viewcam.me or other DDNS on a 4G Router
etrust
edited November 2016 in SecuritySpy
Recently switched from ADSL connection to a 3G/4G network.
I am using a TP-Link TL-MR3420 and the webserver function on SecuritySpy (4.0.6) is working fine on the LAN, but I am unable to access from the web via DDNS.
My research so far suggests that this may be because Mobile ISP block all incoming connections (?). I am on the Optus Network in Australia.
Anyone have any ideas to work around this?
  • Typically this won't work, because the IP address assigned to you from the 3G/4G network will not be a true Internet IP address; it's typically going to be behind your ISP's router. So there is no way to route incoming connections from the internet to your server.
    I'd recommend that you contact your ISP for further information. Please post back here if you find out any further information from them, as this would be helpful for other users.
