Cameras Disconnecting
AtomicLaser1
edited August 2016 in SecuritySpy
Hi, thought i'd check out the trial of 4.0.5 to see if it's improve things with my cameras since trailing 3.4
All my cameras on SS disconnects from time to time, apart from the green one which is running on a Raspberry Pi.
the other cameras are IP cameras, running at 720p and 10fps on a 100MBps POE switch which goes into a 1000MBps hub
Any ideas why this might be happening?
https://s14.postimg.org/5hi4feepd/Screen_Shot_2016_08_28_at_09_47_51.png
  • This very regular pattern of disconnects indicates that the cameras may be doing this intentionally. Could you please let me know the make and model of these cameras, and how they are set up in SecuritySpy (specifically what Profile and Format settings are in use).
  • Hi Ben,
    There's two different makes of cameras involved:
    One is a ANRAN AR-24NW-IP10-POE (probably a chinese cheapo one) configured in SecuritySpy as a ONVIF Camera, with it set as 720p resolution and 10fps on the camera itself.
    The other is a Synshore YS-IPC2.0MP-XYP60 configured in SecuritySpy as a ONVIF Camera, with it set as 720p resolution and 10fps on the camera itself.
    I have also tried setting these as a Manual profile" connecting to the IP xxx.xxx.xxx.xxx:554 and using the request "user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream" with the same kind of symptoms
