Accessing analog cameras connected to a Q-See DVR with SecuritySpy
jish
edited July 2016 in SecuritySpy
Hello, I have 3 analog cameras plugged into a Q-See DVR. The DVR is on my network and I can access it using a web interface, and their iOS app. I can see all my cameras.
I searched and wasn't able to find any guidance on how to add them to SecuritySpy (but I've been successful with 3 LogiTech Alert PoE cameras). Can someone point me in the right direction or give me some guidance on how to add the Q-See connected cameras?
This is the model DVR: Q-See QTH163-2 (https://www.amazon.com/Q-See-QTH163-2-Channel-Security-1080p/dp/B01CEFLQHY)
THANK YOU!!
  • Any help would be appreciated! :-)
  • Tengo el mismo problema
  • Hi, Q-See have a public document called Using RTSP on QC Series DVRs and NVRs, which shows RTSP URLs for your DVR. According to this document, the setup in SecuritySpy is as follows:
    • Create a new network device
    • Enter the DVR's IP address and username/password
    • Set the Profile (device type) to Manual
    • Select RTSP as the Format
    • For the Request, enter cam/realmonitor?channel=X&subtype=00&authbasic=Y, where X is the channel number (1-32) and Y is the Base64-encoded string of username:password
    For example, for the first channel, and "admin" as both the username and password, the Request would be:
    cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46YWRtaW4=
    Does this work?
