"Video Device Setting -> Input Number" corresponds to Axis Stream Profiles?
Hi:
I try to get a second stream of lower resolution from one Axis camera to SS. I tried selecting 640x480 from the resolution dropdown, SS still gets the full resolution. I selected a different Input Number in Video Device Setting but the video stopped.
Is there a way for SS to select a different stream profile from a Axis camera?
Problem solved:
instead of leaving Frame Rate to default, I forced Frame Rate to a defined number in addition to setting resolution to 640x360, then SS gets the low resolution stream.
Good to hear you worked it out. Different cameras treat this "input number" setting differently. For Axis cameras, you can specify the encoding parameters using the other controls in the Video Device Settings window, which gives you much more flexibility than fixed stream profiles.
