SecuritySpy and Verizon
For some reason I can not get to SecuritySpy from the internet. I have wfm.viewcam.me setup and the test button does not return an error. Pinging it returns
MacPro-13:~ wfm$ ping wfm.viewcam.me
PING wfm.viewcam.me (108.56.166.223): 56 data bytes
64 bytes from 108.56.166.223: icmp_seq=0 ttl=64 time=4.015 ms
Request timeout for icmp_seq 1
64 bytes from 108.56.166.223: icmp_seq=2 ttl=64 time=2.896 ms
64 bytes from 108.56.166.223: icmp_seq=3 ttl=64 time=4.328 ms
64 bytes from 108.56.166.223: icmp_seq=4 ttl=64 time=2.518 ms
64 bytes from 108.56.166.223: icmp_seq=5 ttl=64 time=3.337 ms
Not sure what is happing, any help would be much appreciated.
Bill
Bill
Hi Bill,
Your wfm.viewcam.me DDNS name is working fine, so the problem must be the port forwarding settings in your router. Have you followed our Remote Monitoring setup instructions? What router make/model are you using?
