Alnet
Squirrelly
edited May 2015 in SecuritySpy
I have been using Alnet and an SD camera. I'd like to use software that is as feature rich as Alnet with an HD IR camera for outdoor. They charge $200 more for IP camera software. I have spent a bundle on their stuff. Right now The SD camera I am using now has great IR but terrible image. http://platinum-cctv.com/Wide_Angle_Outdoor_IR_Night_Camera.asp. I want to do this once so I am hoping that your software will utilize my existing computer which I am using for Alnet and you can recommend a great Wide Angle HD outdoor IR camera. Thanks in advance
  • Hi Squirrelly,
    The camera you link to is an analog camera, and if you want to hook this up to SecuritySpy can you do so using various methods - please see the Choosing input hardware section of our SecuritySpy Installation Manual.
    However we do not recommend analog cameras, because the resolution is very limited and they produce an interlaced image.
    For a high-quality megapixel outdoor bullet camera, check out the Dahua Technology IPC-HFW4300S - this is one of the cameras we recommend on our 10 Recommended IP Cameras 2015 list, which you might want to have a look at.
    Let us know if you have any further questions.
  • Do you have a phone number that I can reach you at to discuss your software?
  • Sorry, we are not contactable by phone but are very responsive by email, as we have found this to be the most efficient way to deliver good service and support. Alternatively, this forum is a good place to get answers to your questions.
