Two locations/networks - same screen?
devonmfa
edited April 2015 in SecuritySpy
Hi, I have the Logitech Alert cameras running on SecuritySpy. Here's my issue - I've got a separate studio on my property with 2 Logitech Alert cameras and I'd like to be able to view all on one screen. They are on a separate network. Is there any way to access a second network? Thanks.
  • Hi - you will need some way of joining the two networks together in order to view all the cameras together.
    The best way would be to combine the two networks into one, using wired ethernet, by running a cable to your studio. Is this possible?
    The second best way, if the studio is within wireless range, would be to use a wireless access point or router on your main network to create a wireless network (maybe you have one of these in place already), and then in the studio use a "wireless bridge" device in order to join the studio network wirelessly to the main network.
    In last place, if both locations have their own internet connection, then you can connect them over the internet, though this is the slowest, most difficult to set up, and will consume your internet bandwidth.
