Info from ONVIF stream
JohnS
edited April 2015 in SecuritySpy
Recently, I took a chance and purchased a Wemelody WE-EYE03W camera from Amazon, not on the list of cameras that work with SS, but has pretty good specs and was listed as ONVIF compliant. Good image & ir quality camera, but the lack of any documentation and website/support for the company leaves me less than impressed. After three days of tinkering with SS with the manual configuration, I was finally able to get this camera to work by setting the display type as "ONVIF" with the same port numbers I set in the web UI (leaving them blank worked too), and the "RTSP TCP (video and audio)" format, "RTSP over HTTP" did not work at all and "RTSP UDP" worked, but I got some screen flickering.
Now that I got it working, is there a way to find out how to set this up manually? Or, more specifically, what I should type in the "Request" box? I would like to know for scripting...
Thank you
