Indoor Camera Recommendation
I was wondering if anyone can recommend some high quality (4k) indoor cameras, the kind you could put on a table). I would like PTZ, if possible, though PT will work. It's in a room with 25 foot high ceilings so, as much as I would love to put one up top, it's not realistic (plus there's no outlet up there!). Thanks for any advice you can give!
