Audio level control for ViewCam
In a future release could we see an audio volume control added for the cameras with Audio Input?
Do have one more question about viewing the ViewCam remotely via internet and the SS app (which works fine for remotely viewing SS cams while its running. Used the import all cameras in the add camera option in ViewCam, but it gives me a DNS error when i try that. Probably "operator malfunction" on my part :-).
  • In terms of audio, are you finding that some cameras are simply louder than others, so that you want a per-camera volume control to balance this out?
    As for the DNS error, I'm not sure about this and I will need more information to diagnose. It's probably best if you can email us at support@bensoftware.com and include screenshots of the device settings and error message.
  • Separate audio level controls would be good Ben if that could be added. Higher gain for inside cams and being able to turn down the outside cam mics (wind noise, etc.). I'll email you the DNS error stuff if I can't figure it out here.
