import problem & ssl setting problem
Hello,
When importing from a SS server, sometime some cams are not imported. It occurs when importing from 2-3 different servers (50 cams total).
Also, the "use SSL for HTTP connections" is sometime reverted to off when editing the preferences.
Is it possible to adjust the sensibility of the motion détection (it doesn't work well on wide angle cams).
Thanks !
