Unifi G3 Flex picture tearing
  • I'm not quite sure how to describe this, but every 10 seconds or so a part of the frame smears / tears on two of my Flex cameras. I have the latest build of SS, and I can see this occurring on both the Mac and the App.
    I have just removed a couple of Hickvision cameras that were quite old, but I must admit didn't do this!
    At the moment I don't have the Protect controller running so these were both in their standalone mode with everything set to max.
    They were set up with the Unifi profile
    Also every now and again the picture is delayed by 5-10 seconds....
    If I monitor them directly in a browser they are perfect.
    I have a third Hickvision bullet camera also running and that is perfectly stable
    Before I start a load of testing, has anyone seen anything similar, or got any suggestions where to start?
  • It's difficult to imaging exactly what you are seeing, so when this happens could you please take a screenshot and email it to us at support@bensoftware.com. A screenshot either from the Mac or the iOS app would be fine.
    A network issue is a common cause of these types of problem. How is your Mac and this camera connected? Ideally they should both be wired into the same Gigabit Ethernet switch, is this the case?
  • I have suffered similar with the Unfi G3. The only fix (sadly for me) was to reduce frame rate and connection speed down to around 1mb. These run fine at full connection speed and frame rate in unifi protect software. I suspect it's something to do with how the RSTP is fed from the camera as it needs to be in stand alone to work in security spy. ? I have tried the preset profile in security spy - and manually yet still the only fix seems connection and frame rate related. In my setup they have dedicated cat6 ethernet yet running them throttled. real shame.
  • They’re connected on Gb switch, and yes lowering the frame rate to 10 seems to have cured it, enough to be useable. I have a G3 and G3 pro coming So will try them soon an see if I get the same.
    Also got a UDM pro coming so will run protect and then try streaming from protect, that may work better?
  • Unfortunately running from udmpro had zero affect for me. still had to be low frame rate and throttled connection speed. I have not a clue why. I wonder if Ben can help?
  • Been trying to catch it but it doesn't happen very often and last only about a second. But usually the bottom third of the picture blanks out or goes fuzzy and it freezes for a few moments.
    I can confirm I've now added UDM Pro and I still see it if I bump up the frame rate, its annoying mostly because it triggers the movement alert
  • I am convinced its how Security Spy looks at the incoming RSTP feed as running on Unifi I can run uptp 30Fps and 3Mbs with zero issues. but on security Spy am in the 10fps and under 1mb just to get stability. Ben can unifi be doing something with the RSTP to affect it in this way? thanks
  • I’ve also noticed high latency using the UniFi cameras. I’m pretty sure it’s SS as when I restart the app it catches up.
    I’ve got three G3 cameras and display the time on the screens and can often see one camera in particular be 40 seconds plus delayed. I’m using a quad core Mac Mini and it doesn’t appear to have high cpu usage. Any suggestions?
  • Ben any ideas what can be causing the loss of sync / need to have low frame rates and connection speed to work? Any pointers would be useful.
  • I'm not sure what could be going wrong here. Issues with delay usually only happen with the Mac's CPU is overloaded and can't process frames as fast as they are arriving.
    @evansgo are all your cameras the "G3 Flex" model?
    @jeff444 do you also have the "Flex" cameras, or some other G3 model?
  • Hi Ben the model is UVC G3 I have checked the CPU and its only 11% on this stream with hardware decoding and H264. It never goes past 15%. Really confusing as other streams using cheap cameras are doing higher frame rates and connection speed with no drop in sync/stuttering etc.
    In addition I have tried running from theRSTP stream in unifi protect and using the camera in standalone mode with the same issues. makes no sense to me at all why this should not work in a stable way? Also tried 2 separate cameras with same results. its weird.
    UVC-G3-Bullet / UVC-G3-AF
    • 1080p Full HD, 30 FPS
    • EFL 3.6 mm, ƒ/1.8
    • Outdoor Weather Resistant
    • 802.3af PoE or 24V Passive PoE
    • Built-in Microphone
    • Wall, Ceiling, or Pole Mount
    • High-Power IR Range Extender
  • Hi Ben, currently I have 2 x G3 flex and 1 x G3 pro. Nothing is looking overloaded, the mac mini is not close to working hard. The delay seems to have got better the longer its all left running and I noticed this exact same thing when I only had one G3 flex in standalone mode, for the first day or so it was awful, but then the lag slowly vanished. Never saw it with the hickvision cameras
  • Thanks for the info. I agree, it's very strange, there is no reason for such problems if the Mac's CPU is not overloaded. We've ordered one of these cameras to test with, and when it arrives I hope we will be able to improve things (if there is anything we can do on our side).
  • Thanks so much I have a few of these and would love to use them to replace my cheap china grey market cameras but at moment they are pretty much too unreliable. Thanks ben!
  • Brilliant thanks, let me know if I can help do any testing, I have 5 cams now so can load it up a bit to test stuff
  • I have noticed over time that although one camera connected direct to poe switch over time it slowly drops out of clock sync. Then it starts to have a loss of over 80%. tried different ports / cables and switches. The same slow degradation. I power reset on the camera resets and drift starts after a few hours again.
  • We have received our UniFi camera and have been testing with it, and we have seen a problem that manifests after 10-30 minutes or so, whereby the camera's data rate drops dramatically, the video is delayed, and there is significant packet loss resulting in corrupt video.
    As far as we can tell this is not something that SecuritySpy is doing - the actual data coming in is compromised at this point, and nothing can be done to decode it properly.
    One solution we have found is to use UDP transport rather than TCP transport. TCP is usually more reliable, but we do come across cameras from time to time that have problems with TCP for whatever reason, and operate much more reliably over UDP. UDP should work well provided you have a fast, reliable, wired network in place (not WiFi).
    So, in the latest 5.2.4b12 beta version of SecuritySpy, we have enabled an "RTSP UDP" Format option, which can be selected under Preferences -> Cameras -> Setup.
    So could you please all try this and report back.
  • OK have tried it but it wont connect. Tried it with a G3 Flex and a G3 Pro, I get timeouts.
    I am connecting via Unifi Protect though and not with the Cams in standalone mode, not sure if thats making the difference.
    The only format I can get to work is RTSP-over-HTTP, RTSP on its own doesn't work either, maybe I have something incorrectly set up?
    IP is the UDM Pro
    HTTP set to 7447
    RTSP set to 554
    USername and password are correct
    Manual Config
    Format is RTSP-overoHTTP
    Request has the designated code in it.
  • Connected fine - power cycled cameras and will run for a day and see the results on UDP.
    Normally the daily report highlights the packet loss so will wait to see what it throws up over the next reporting period. Thanks.
  • Camera 1 with Beta release 12 UDP
    - 105 movie files recorded
    - 0 image files recorded
    - 609 MB of data recorded
    - 29 errors
    - 99.8% camera uptime
    Camera 2 Beta with release 12 UDP
    - 178 movie files recorded
    - 1.6 GB of data recorded
    - 34 errors
    - 99.6% camera uptime
    Beta Release 10 and running on TCP
    Camera 1
    - 67 movie files recorded
    - 246 MB of data recorded
    - 63 errors
    - 99.7% camera uptime
    Camera 2
    - 251 movie files recorded
    - 1.0 GB of data recorded
    - 60 errors
    - 99.9% camera uptime
    - 6 of 6 cameras currently online
    - 5605 movie files recorded in total
    - 0 image files recorded in total
    - 51.7 GB of data recorded in total
    - 99.9% software uptime
    - 12% average CPU usage
    - Normal memory pressure
    A decrease in ERRORS and both have remained in clock sync - will have a real 24 hour result tomorrow
    Looking much better so far!
  • What quality stream are you using in Protect? I just cannot get the stream to start in SS on any settings apart from RTSP over HTTP? I tried a camera restart but no luck
  • OK I found the problem, in case it helps anyone else I had the ports wrong. The RSTP needs to be 7447 in this configuration.
  • Good to hear you found the solution @evansgo. Is it working better with UDP?
    The best way to compare is to use the Dashboard feature (either in SecuritySpy's macOS interface itself or via its web interface) and look at packet loss for these specific cameras when using TCP vs. using UDP. Are you both seeing a significant difference here? We certainly are with our test camera.
  • Looking really good today but I have noticed a new issue :-
    motion capture mode has been disarmed. (Failed to record video frame 5575,818 The key frame interval from the network device is too high, locate and change this setting in the device (may be called I-frame interval / I-frame rate / GOV length / Intra frame period))
    Regards
  • Well I wasn't seeing the packet loss problem myself, but since I installed the beta and found the port issue, its all working really well. I've upped the frame rate back to where I wanted it and everything is looking good and perfectly in sync across four cameras
