Capture Frequency - Seconds Between Frames
  • This feature has been absent since around version 3.4.1. Now we only have "frames per second." Is it possible to restore this very useful option in future updates?
  • We will consider this for a future update, but for now you can enter a frame rate of less than 1, for example a frame rate of 0.25 is equivalent to one frame every four seconds.
  • Thank you. I'd missed the leading zero. (Starting with the decimal point doesn't work.) Problem solved.
  • Seconds Between Frames is still the better way for time-lapse, I think, after some tests. I'll go back to the older version for now. Thanks again.
