motion detection recording based on AI type
  • Hi
    Sorry if its already been requested could not spot it doing search.
    So I mainly use motion detection recordings, it would be good if motion recordings only happen based on AI detection type e.g. Person, Car
    The AI detection has been great btw, its reduced false notifications that I setup via indigo 7, it would be great if recordings could do the same :)
    thanks
  • Yes, you can configure this via Preferences -> Cameras -> Triggers.
    There are separate AI controls for Motion Capture vs. Actions, so you can enable the AI for either notifications or recording, or both, as required.
