Problem with Amcrest Camera
  • I just added an Amcrest IP2M-842E bullet cam POE. I am constantly getting a green flashing cutting in and out with the video. Any suggestions?
  • This can indicate problems with your network. Is your Mac connected to the network by WiFi? If so, I would recommend connecting it by wired ethernet instead.
    The next thing to do is check for and apply any firmware updates available for your camera.
    Another thing you can try is to reduce the frame rate at which the camera is sending video.
    Finally, make sure you are using the latest version of SecuritySpy.
