Recording issues - Reolink RLC-423, continuous recording
  • Reolink RLC-423 Upgraded to Sierra 10 days ago. Camera views are fine and smooth, when I look at recordings in browser the recordings are 1 frame every 2 seconds. I am using continuous recording, no recompression and the recommended setting from the source which have worked great in 10.11 for a couple of months.
  • I'd do a quick check of the file directly from the finder using quicklook, or loading it into quicktime and see if it's fine there.
  • Those files won't play in QT OR VLC.
  • Clean reinstall and reducing max bit rate output from camera seems to have solved problem. Will update if that changes.
  • Glad you found a way to get it working. With my camera's (either H.264, or JPEG) the files have always worked from the finder, even when I've run into glitches with the SS browser.
