Docker Wyze-Bridge sound
I'm not proud of it, but I have a half-dozen Wyze cams I've accumulated over the years for hobby things. If my kids make a squirrel trap (that doesn't harm them), then I throw a Wyze cam in there plugged into a USB battery pack. etc.....
I use wyze-bridge docker to convert them into RTSP feeds that feed into SS.
They've worked forever, but I could never get sound. I found documentation to add sound via docker variables, and now the Wyze Bridge GUI gives me sound.... but SS doesn't show the audio is getting to it.
Anyone know what I might be missing?
The main thing to check is that audio is enabled for this camera in SecuritySpy under Settings > Cameras > Audio: the source should be set to "This network device". Does this do it?
That setting is already correct.
The dashboard shows no audio associated with the stream.
So I think I have an RSTP stream issue (served from docker-wyze-bridge), and nothing to do with SS, but if anyone else has this setup and can assist, please let me know.
