How to reduce motion videos caused by rain and snow
I'm getting dozens of videos of rain and snow even though I have autos and humans specified. Are there settings I can use to limit these videos?
  • Your settings look fine (except the vehicle threshold which is set far too low, however vehicle detection is turned off so this shouldn't matter). So, I'm surprised that you're getting lots of false detections, as these should be effectively screened out by the AI.
    To investigate what could be going on, I would recommend following the instructions in this article to create an "AI Predictions" folder, to gain insight into what the AI is detecting and where these errant triggers are coming from. Once you have collected some images using this method that demonstrate the problem, feel free to email them to us (support@bensoftware.com), so we can provide some further advice.
