Mac Pro 5,1 and OpenCore
I decided today to upgrade my Mac Pro 5,1 to Catalina (using Dosdude1 patched installer). Afterwards, I installed OpenCore to enable a boot screen for my unpatched AMD Radeon RX 850 metal card. One of the features of OpenCore is enabling AMD H264 / HEVC hardware decode + encode in Mojave or later. I don't recall SecuritySpy's exact CPU usage prior to OpenCore, but I think with all 13 cameras being viewed, usage was probably around 40-50%. After installing OpenCore, SecuritySpy CPU usage is hovering around 1.5%. That's quite a big boost in performance. Right now, I'm just viewing the cameras on the Mac Pro since recording is done via my Mac Mini. I'm curious, if I move my license copy of SS back to my Mac Pro, would SS benefit from this performance boost when recording video.
Have you implemented this procedure for enabling AMD H264 / HEVC hardware decode + encode (on the RX580) in later versions of macOS — more specifically Ventura? I have a 2010 12-core with NVIDIA GT630 / 2, and it won't decode video streams from my low-end Amcrest PoE cameras in Ventura 13.2. The identical setup (cameras / hardware) and the same version of SecuritySpy (5.5.4) work like a charm in Big Sur (on a separate PCIe bootable SSD). I skipped over Monterey on this machine; Ventura is also on its own PCIe drive (both SSDs are Samsung 970).
Also...I ordered a RX580 / 4 flashed card from macvidcards.com yesterday. A worthy upgrade at a very decent price, even if it doesn't put me on the road to solving this particular problem.
