Camera tripped but doesn't continue recording
  • Question. The camera is tripped by motion and starts recording. (Great.) But then after a brief time, while motion is still happening, the camera stops recording. (Bad.) I moved the sensitivity to 90, but that's not helping. How do I fix this?
    Thanks!
  • SecuritySpy does continue to record as long as it's detecting motion, so it must be the case that after the initial trigger, the amount of motion present is too low to keep triggering. The solution is to increase the post-capture time via Preferences -> Cameras -> Motion Capture - for example, try 30 or 60 seconds.
  • Thanks, Ben. I may also look at boosting sensitivity higher. (There's a very low possibility of false positives.)
