if motion is dedected, is it possible to automatically let the light turn on and have a recorded dog
I find the answer in the manual now: http://www.controlbyweb.com/x17s/
will be the solution for the light switch and I guess a camera with loudspeaker will we the solution for tha "barking dog" -
Yes, the WebRelay devices by ControlByWeb are very good and can trigger things like lights.
As for a barking dog, SecuritySpy can play sounds when motion is detected (see the Actions section of the Camera Settings window). So if you can obtain a barking dog sound as an AIFF or MP3 file, simply move it to the ~/SecuritySpy/Sounds/ folder and it will be available in SecuritySpy. Then hook up a speaker to your Mac's audio output. -
I have a simple PIR (£15-00) that switches on an outside light and a table lamp in my living room and a TV flicker device which duplicates the flickering light of a TV upon motion detection. It's all hard wired of course but very simple to do.
