Remote Patrol HD & SSL
  • Hi, I have just enabled SSL connections using a self signed cert on my securityspy server. HTTPS connections are working from a browser on my laptop on my home network but I cant get them to work remotely using a browser or remote patrol. I get prompted to trust the cert but then get a timeout. It looks as though the connection is getting redirected to the internal LAN ip address which isn't routable on the internet. Is there a way to get this working? Remote Patrol is also failing when on my home network, should this work?
  • Got it working, I missed out part of the rewrite statement in the Apache SSL config file.
