RemotePatrolHD does not search outside default location
  • I just started to use SecuritySpy and Remote Patrol HD. RPHD works fine to search through old files if I use SS default folder location inside Documents. Once I change it to another drive, RPHD shows empty folders for any search. I know that SS does record files correctly to the new folders and I can browse them directly or through web interface. But Remote Patrol cannot see them. Any suggestions? Thanks.
