Foscam FI9851P - connection closed
  • Hi, I’ve been using your great software for years, but I hope you can help me with the latest Foscam-dome:
    FI9851P V3
    1.12.5.4
    It says «connection closed» in Securityspy, in Safari and other apps it works fine.
    The first version:
    FI9851P
    1.5.3.19
    Works just fine.
    Can you help me with this?
    Thanks in advance.
  • Unfortunately we have seen lots of problems with Foscam cameras, which is why we advise against them on our list of supported cameras.
    What profile are you using in SecuritySpy? I would recommend trying the "Auto-Detect Profile" button via Preferences -> Cameras -> Device to see if that yields any results.
    Failing that, I would strongly recommend you return this camera and get a non-Foscam one that's shown as compatible on our list.
