Camera freezing causes motion detection to trigger
I have a script to manually control the IR on my camera because the built-in automatic IR control in the camera is unreliable (It'll turn on even when there is enough light). This script detects the light level in the room, checks if the camera in question is "ACTIVE" in SecuritySpy, sets it to "PASSIVE", turns the IR on or off, then 7 seconds later re-activates the camera. I do this to prevent the IR change from triggering motion detection, as it has happened. Here's where the problem comes in: SecuriySpy is detecting motion because it would seem the camera is "freezing" and then resuming. I can't be sure what's happening in this situation, but I thought SecuritySpy was designed to ignore motion triggers that are the result of a full-frame change, such as lighting.
The camera is a DCS-5020L.
My settings for this particular camera are post- and pre-capture 5 seconds, recompress video is off, recompress audio is on.
Here's the video it captured: http://bit.ly/MotionError
Here's the mask setup for the camera: http://i.imgur.com/Nvx7H4P.png
The camera is using wi-fi via Internet Sharing connected directly to an iMac running SecuritySpy in a virtual machine, so bandwidth is not an issue.
Normally this wouldn't be an issue, but this particular camera is used for intruder detection and triggers an alarm. I understand this is probably an issue with the camera itself when toggling IR, but any help with this would be appreciated!
I can deal with the false-positives, though. I just wanted to know if I could prevent them—it scares my dog!
